How to replace a PCV valve. In order to access the PCV valve, you have to remove the intake manifold. Yes, you read that right. Toyota (via AllData DIY) wants you to take the manifold and throttle body completely off. That's completely unnecessary. The job is not as complex as it seems.
This is a reference video on what the job entails and reinforces my prior two sentences:
Tools needed:
Torque wrench
Socket wrench extensions
10mm socket
12mm socket (both shallow and deep)
Telescoping magnet or equivalent
22mm deep socket
Panel puller or equivalent
Hose clamp piers or regular pliers
Red Loctite or equivalent
PCV valve - Toyota Part Number 12204-37010
Remove the cover.
The image above is a reference of everything that needs to be removed.
Start by disconnecting all of the hoses as indicated. All except one hose you can remove by hand. Use the hose clamp pliers or equivalent to remove that one hose. You may have to work the hoses out if they never been removed.
Remove the hose from the top of the engine, throttle body (10mm socket) and air box (10mm socket)
Pull the hose out of the car and set aside.
Disconnect the wire harness clamps where indicated. I used a panel puller for one and the other was easy to remove without tools by moving the loosening where it locks. You can try to remove the ones from the bottom of the intake manifold. I found it easier to remove them once the manifold bolts/nuts were off. I disconnected the harness clamp from the front alternator. It made it easier to access the other harness clamps which I removed from the rear as it was easier to squeeze one side out at a time and push out.
Begin removing the bolts and nuts attached to the intake manifold. See the the next several images for exact locations.
Use your magnet when removing the nuts from the intake manifold, that way it won't drop as soon as you remove your socket.
Once the bolts are removed, pull the intake manifold stay out and set it aside. You can now move the manifold off the engine.
If you haven't already, disconnect the remaining harness clamps attached (2) to the intake manifold.
Carefully move it aside without banging the throttle body too much and you'll see where the PCV valve is located.
Remove the hose connected to the PCV valve.
Use your 22mm socket to remove the PCV valve. Warning, it's on tight.
Once you have the PCV valve out, compare the old to the new one.
It should look like the next picture
Once you've confirmed the part is correct, add Red Loctite or equivalent and thread the PVC valve by hand.
** If you used Red Loctite, it's advised to let it cure for an hour before you begin driving the car.
Use socket to tighten the PCV valve the rest of the way. Torque spec is 20 Nm or 15 ft-lb
The next picture shows the PCV valve installed and the hose attached.
Reassembly (no pictures).
You can replace the intake manifold gasket if you choose to do so. I made the choice not to with no ill effects.
Reconnect the two harness clamps to the bottom of the manifold.
Place the intake manifold back in its normal position.
Replace the intake manifold stay in its proper place.
Reattach the bolts/nuts to the intake manifold. Torque spec is 28 Nm or 21 ft-lb.
Reattach the hose to the the air box, throttle body, and the top of the engine.
Reconnect all of the hoses that you haven't already attached.
Reattach any harness clamps that you detached.
Replace the engine cover.
Congratulations, you just changed the PCV valve!
