1 - 15 of 15 Posts
10th Gen Addict
2011 Toyota Corolla
The Everything You Need To Know Thread!
Year / Models / Engine Code / Transmission:
2014-2016 / CE/L / 2ZR-FE / MT (6 Spd) & AT (4 Spd)
2014-2016 / LE / 2ZR-FE / AT Only (7 Speed CVTi-S)
2014-2016 / LE ECO / 2ZR-FAE / AT Only (7 Speed CVTi-S)
2014-2016 / S / 2ZR-FE / MT (6 Spd) & AT (7 Speed CVTi-S)
2017- / CE/L / 2ZR-FE / MT (6 Spd)* & AT (7 Speed CVTi-S)
2017- / LE / 2ZR-FE / AT Only (7 Speed CVTi-S)
2017- / LE ECO / 2ZR-FAE / AT Only (7 Speed CVTi-S)
2017- / XLE / 2ZR-FE / AT Only (7 Speed CVTi-S)
2017- / SE / 2ZR-FE / MT (6 Spd) & AT (7 Speed CVTi-S)
2017- / 50th & XSE / 2ZR-FE / AT Only (7 Speed CVTi-S)
CE(L)/LE/LE ECO Style on Left & S Style on Right
Models may Vary!
Mid-Generation Refresh
Corolla 1.8L VVT-I
Trims: CE/L, LE, S/SE, XLE, XSE
Chassis Code: ZRE172
Engine Code: 2ZR-FE
132 HP @ 6000 rpm
128 lb.-ft. @ 4400 rpm
Transmissions:
-6 Speed Manual (CE/L & S/SE)
-4 Speed Automatic (CE/L)
-7 Speed CVTi-S (CE/L, LE, XLE)
-7 Speed CVTi-S w/ Sequential Multi-Mode Shifts (S/SE, XSE)
Corolla 1.8L Valvematic
Trims: LE ECO
Engine Code: 2ZR-FAE
140 HP @ 6100 rpm
126 lb.-ft @ 4000 rpm
Transmissions:
-7 Speed CVTi-S
Weight and Capacities
Curb Weights kg(lbs):
CE/L 4Spd AT - 1,275 (2,811)
CE/L 6Spd MT - 1,265 (2,789)
LE CVT AT - 1,290 (2,844)
LE ECO CVT AT - 1,290 (2,844)
S CVT AT - 1,295 (2,855)
S 6Spd MT- 1,285 (2,833)
Mid-Generation Refresh:
CE/L CVT AT - 1,288 (2,840)
CE 6Spd MT - 1,275 (2,830)
LE CVT AT - 1,301 (2,870)
LE ECO CVT AT - 1,292 (2,850)
XLE CVT AT - 1,301 (2,870)
SE CVT AT - 1,308 (2,885)
SE 6Spd MT- 1,297 (2,860)
XSE CVT AT - 1,308 (2,885)
Towing Capacity kg(lbs)(Only for 6 Speed): 680 (1500)
(Not Recommended by Toyota)
Fuel Tank gal(liters): 13.2 (50)
Fuel Economy (MPG)(city/highway):
CE/L 4Spd AT - 34/44
CE/L 6Spd MT - 33/43
LE CVT AT - 34/46
LE ECO CVT AT - 37/50
S/SE CVT AT - 36/42
S/SE 6Spd MT- 34/44
Color Codes and Colors:
3R3 Barcelona Red Metallic
209 Black Sand Pearl
1F9 Slate Metallic
1F7 Classic Silver Metallic
8W7 Blue Crush Metallic
040 Super White
070 Blizzard Pearl
6W3 4EverGreen Mica
4V8 Brown Sugar Metallic
3P0 Absolutely Red
3P2 Black Cherry Pearl
1G2 Falcon Gray Metallic
221 Galactic Aqua Mica
Wheel and Tire Specs
Basic Specs
Bolt Pattern: 5x100mm
Thread Pitch: 12x1.5
Hub Diameter: 54.1mm
Factory Corolla CE/L Specs
Wheels: 15" Steel Wheels w/ Wheel Covers
Offset:+33mm
Tires: 195/65R15
Factory LE/XLE Corolla Specs
Wheels: 16" Steel Wheels w/ Wheel Covers (Optional 16" Alloy)
Offset:+39mm
Tires: 205/55R16
Factory LE ECO Corolla Specs
Wheels: 15" Steel Wheels w/ Wheel Covers (Optional/Available w/ package 16" Alloys)
Offset:+33mm (With optional 16" wheels +39mm)
Tires: 195/65R15 (With optional 16" wheels 205/55R16)
Factory S/SE/XSE Corolla Specs
Wheels: 16" Steel Wheels w/ Wheel Covers (Optional/Available w/ package 17" Alloys)
Offset:+39mm
Tires: 205/55R16 (With optional 17" wheels 215/45R17)
Bulb Sizes
High Beam Headlamp: 9005
Parking Light: 7444NA
Front Turn Signal: 7444NA
Rear Turn Signal: 7440A
Tail Light: 7443
Brake Light: 7443
3rd Brake Light: LED Assembly
Fog/Driving Light: H16
License Plate: 168
Reverse Light: 921
Front Sidemarker: 168
Rear Sidemarker: 7443
Map Light: 168
Dome Light: DE3175
Trunk/Cargo Area: 168
Turn Signal Light Front Outer: 2827
Vanity Mirror Light: DE3022
Model Year Changes
2014
-introduction year/first year of production for the 11th gen Corolla​
2015
-rear center seat armrest was added
-LE front bumper now has grey accents instead of the carbon fiber accents
-50th Anniversary Edition now introduced in Canada
-minor trim changes
-A/C now an option on CE trim​
2016
-Special Edition trim introduced in USA (limited to 8,000 units)
-6.1 inch radio now replaces old stock radio in L trim(stock radio is still standard on CE trim)
-minor trim changes
-Oil filter design changed from cartridge style to spin-on style
-Corolla hatchback launched in North America as the Scion iM
2017
*Mid-Cycle Refresh*
-Toyota Safety Sense P (TSS-P) is standard on all models
-redesigned front bumpers
-two new headlights available: Bi-LED Headlamps (CE/L and LE trims) & Multi-LED Headlamps (SE and XLE trims)
-two new taillight designs: Base taillight with NEW amberish-pink tint for reverse light and signals & fully red taillight with LED reverse lights for SE trims
-new dashboard and interior designs (used in iM)
-new gauge cluster designs: Stock cluster with 3.5” Multi-information Display (CE/L,LE,LE ECO) Premium cluster with 4.2” Multi-information Display (XLE, 50th) Sport cluster with 4.2” Multi-information Display (SE, XSE)
-6 speed manual is still offered in Canadian CE trim and SE trim but is no longer in the U.S. "L"/Base trim (6 speed manual currently only offered on U.S. SE trim)
-4 speed auto is completely discontinued from all trims and is replaced by current CVT
-windshield wiper de-icer system now available on certain trims (LE trims and SE trims)
-heated steering wheel option added (LE trims and SE trims)
-auto AC standard on LE trims and SE trims
-front sun visors now have an extendable component
-foglights replaced with DRL lights
-newly designed wheels and hubcaps
-S trim renamed to SE and XLE & XSE trims introduced
-special 50th Anniversary trim added limited to 8,000 units and includes unique parts
-front 3D Toyota emblem replaced with 2D emblem with sensors
-basic radio removed and replaced with a 6.1" system while higher trims get a 7" system
-Siri Eyes Free standard on all radio systems
-new colors added
-front body structure changed/stiffened to excel in IIHS small overlap crash test (rewarded with "2017 Top Safety Pick+")
-rollover sensors now standard
-iM officially added to the Corolla lineup (now know as Corolla iM) as a hatchback model
-fuel economy ratings went down due to new harsher economy testing
-new prices
2018
-XLE trim introduced in Canada
-50th Anniversary trim discontinued in the US
-front sun visors now feature illuminated vanity mirrors
-some new trims receive leather-wrapped steering wheels
-rear cupholders mounted to the center console have been replaced with a storage pocket
2019
-minor price changes to U.S. models
-addition of optional 16" alloy wheels in gunmetal grey or silver for Canadian models
Frequently Asked Questions
What are the Engine and Transmission codes for the US spec 11th gen?
The engine codes are 2ZR-FE(VVT-I) and 2ZR-FAE(Valvematic). The transmission code for the 6 speed manual is EC65, the CVT is K313, and the 4 speed auto is U341E.
What is the thread size of the gear shift knob?
The thread size of the automatic shift knob is M8x1.25 while the shift knob for the manual is M12x1.25(need confirmation).
What are some common torque specs for the Corolla?
Most of them should be listed here: http://i992.photobucket.com/albums/af41/kobyg91/SCAN0003_zpsdycu33gs.jpg
*Canada Only
**USA only
10th Gen Addict
2011 Toyota Corolla
Discussion Starter · #2 · (Edited)
Corolla iM/Hatchback
(formerly Scion iM in 2016)
2016-2018 / Base / 2ZR-FAE / MT (6 Spd) & AT (7 Speed CVTi-S)
Models may Vary!
Trims: Base
Chassis Code: ZRE186
137 HP @ 6100 rpm
Transmissions:
-6 Speed Manual
-7 Speed CVTi-S
Base HB CVT AT - 1375 (3031)
Base HB 6Spd MT - 1335 (2943)
Fuel Tank gal(liters): 14 (53)
Base HB CVT AT - 34/43
Base HB 6Spd MT- 32/42
070 Blizzard Pearl
8X7 Electric Storm Blue
6W2 Spring Green
Basic Specs
Bolt Pattern: 5x114.3mm
Hub Diameter: 60.1mm
Factory Corolla iM Base Specs*
Wheels: 17" Aluminum Wheels
Offset:+39mm
Tires: 225/45R17
Bulb Sizes
High Beam Headlamp: 9012
Parking Light: LED Assembly
Tail Light: LED Assembly
Brake Light: 7440
Fog/Driving Light: N/A
License Plate: 194
Reverse Light: 921
Front Sidemarker: 194
Rear Sidemarker: LED Assembly
Map Light: 175
Dome Light: DE3175
Trunk/Cargo Area: DE3022
Model Year Changes
2016
-introduction year/first year of production for the 11th gen Corolla Hatchback in the North American market; introduced as the Scion iM
2017
- brought to Toyota as the Toyota Corolla iM due to the end of Scion
- Toyota logos replaces Scion logos including on the Pioneer headunit
- new standard features such as TSS-C as well as other features are added
- new prices and options/accessories
2018
- final model year for iM in North American market; succeeded by 12th Gen Hatchback
- no major changes made aside from pricing and/or accessories
10th Gen Addict
2011 Toyota Corolla
Discussion Starter · #7 ·
It's M8x1.25, I have an adapter to run an M12x1.25 shift knob (which was a PITA to find an adapter that size btw).
Is that for auto or manual? I remember hearing somewhere that the manual and auto are different sizes. Correct me if I'm wrong.
Spock-a-like
2015 Corolla S Plus
You are correct, they're different. The M8x1.25 is for the auto. I was told the M12x1.25 is for manuals but since I don't have a manual I can't verify lol
14 Corolla S+
2014 Corolla S CVT
Denso Part #s for Wipers and Air Filters
These blades are the ones that come from the factory and in my opinion are the best blade out there. Denso makes 2 lines of wiper blades that will fit our Corollas but the "designer" line is what we get from the factory, and in my opinion look better, not to mention the blade is made of better material (graphite blend or something) .
As far as the air filters go I dont know where Denso (OE) stands compared to bosch, and FRAM etc. I do know "performance" filters like k&n give better airflow but allow more dirt to pass through.
Right Wiper Blade (16") # 160-3116
Left Wiper Blade (26") # 160-3126
Engine Air Filter # 143-3005
Cabin Air Filter # 453-1019
1 - 15 of 15 Posts
