I should have mentioned that it is a 4wd- 22re
my 85 EFI Auto does the same thing he probably had stock gears in it which i believe is why mine has a highway issue. I also stretched my chain do to the timing chain tensioner going out..if he didn't say he replaced everything that has to do with the timing chain you want to be careful because from what i have been told, once the chain stretches you need to replace the tensioner and chain guides(cause the chain will tear the apart after it stretches) and chain. If he didn't do that i would be Leary too. the power issue probably isn't as bad as your thinking i haven't talked to too many guys with yota's that can get 70 on the highway i know i cant and my motor is tuned and only has 30k miles on it.Yeah this truck had the EFI but it was an Automatic, which I did not want and I know there was something wrong with the tranny. Well before I made it on to the highway I noticed the gas pedal was really hard to press and the tranny shifted terrible. It would downshift going 50 mph and you wouldn't go any faster, it would just sound like the engine was red-lining. It had 32x11.50's and I know that did not help but the power was terrible. the body may have been pretty good on rust, but it was banged up too. what do you think.-
By the way, it had originaly come from a 19 year old who said " I stretched the timing chain but I did not break it, so I replaced it" - How in the world do you stretch the timimg chain.
Is the frame rust worse on 85's or all strait axles? Also, the Tranny felt terrible, the body was pretty dinged and there was oil all under the front on the bottom of the motor. Somebody told me you couldn't find one that did not leak oil but it scare me so I backed out.
Thanks
