Only issues you may run into is a change in your speedometer readout. ie. your speedo will indicate a speed which is slower than you are actually travelling. You can check the differences between your stock tire and any other tire here:
Also, you have to be concerned about the width. There is less than an inch clearance between stock tire and the strut so adding a bigger tire may result in contact between the two.
1 - 2 of 2 Posts
