1 - 7 of 7 Posts
2018 Camry XSE V6
I found this product on Ebay to be cheaper than the Navik's Motion Lockout Bypass.
Have anyone try this for their 2018 Camry?
If so, does it work with Carplay and does it affect the Bird Eye View when shifts into D? Thanks.
Sent from my GM1917 using Tapatalk
2018 Camry XSE V6
What do you mean if it works with carplay?
It shouldn't mess with the birds eye view, it just tricks the system into thinking it's not in drive.
2018 Camry XSE V6
Thanks for the answer. For Carplay when the vehicle is in motion, you can't use the keyboard input for the map and browse the playlist for songs. Will this product bypass that also?
I had it on my 2018 prior to trading it in for the 2019 hybrid. Unfortunately, there was no carplay update yet, so can't confirm that, but everything else worked perfectly fine. Display art, addresses in scout when in motion, mkv movies in motion. Only side effect is auto sound level will no longer work, basically it will always behave as off.
2018 Camry XSE V6
Discussion Starter #6
Thanks for the info!
2018 Camry XSE V6
Discussion Starter #7
1 - 7 of 7 Posts
