I normally change the PCV valve at 30,000 intervals. 20R engine
Just out of curiosity, I pulled mine (OEM Toyota), and tested it per the FSM. When blowing air from the crankcase side to intake manifold side, air flows freely.But when blowing the other way, intake manifold towards crankcase, NO air can flow. The FSM says that air should flow "with difficulty" in that direction.
Also, there is barely any rattle when shaken, as compared to the new valve (Standard Motor v168)- OEM PCV valves are no longer available.
I always thought that a clogged PCV would block flow from the crankcase to the intake manifold (leading to oil leaks and other problems), no? What ill effects would there be if there is a one-way blockage like I had? (24,000 miles since last replaced)
