I'm changing my oil pan gasket soon. As part of the procedure, the FSM says to remove idler arm bracket bolts(this is straightforward) and the motor mount bolts.
Question: are these the bolts that connect the engine mount to the block (four on each side) or are they talking about loosening the one nut (each side) on bolt from the center of the insulator?
Diagram:http://parts.lakelandtoyota.com/sho...1646&ukey_driveLine=6682&ukey_trimLevel=18220
