1 - 7 of 7 Posts
One with the farce
Yes it’s a direct swap, however the early transmissions aren’t as strong as the W56, which will bolt right in, but I do not know if you’d need to trim your transmission tunnel to fit the shifter.
Discussion Starter · #3 ·
Gotcha, this helps a lot man. I think I will attempt to do it myself because the transmission shop is quoting me $800 just to pull the transmission and verify the bolt pattern. Anything I should know before trying the swap myself?
One with the farce
That’s insane, they must charge 400/hour if that’s what they’re doing lol. It’s pretty straightforward, so if you’re mechanically inclined then you won’t have a problem.
Discussion Starter · #5 ·
That’s what I said… I think I can do it with a friends help. Might just invest in a transmission jack
That is one clean old truck (y)
Hope my truck looks that groovy at 40, it sure is a chore in it's environment
Reactions: junior.vcm
1 - 7 of 7 Posts
