G
Guest
·1984 Toyota pickup with the trusty 22R engine. Had to replace the
alternator.Battery's good, but was running out of juice due to alternator
not charging. Anyways, pulled in up in the drive, and installed new
alternator. But, once everything was back together, only headlights and
hazard lights work. Turn the key, and only "charge" light comes on. Had an
open fusible link, but managed to work with it to get continuity. Still
wondering about the voltage regular. The inside looked fairly clean, but
not exactly sure how bad the points might be, even after testing it.
Anyways, all other fuses are good, and all connections I've checked so far
are good. Now I'm just mad and frustrated. Never run into this in all the
Toyota pickups I've owned. Anyone run into this before, seen it on someone
else's, or had the same problem of your own? Whatever y'all think it might
be, throw it out there. I'm very open to any ideas right now. Thanks.
