1 - 11 of 11 Posts
"insert funny line here"
1985 Toyota Pickup
when my truck is at idle, the charge light and the parking brake lights come on, as soon as i speed up the motor however, they go off. could it be my alternator? (replaced 1 month ago) could it be a voltage regulator? please help.
1985 Toyota Pickup
Discussion Starter #2
Ttt
Soylent Green sales
rock crawler
Even tho you just replaced the alt, it sounds like a bad alt.
If it were the orig alt I'd say worn brushes.
Rebuilts have about a 50% failure rate.
BTW, the CHRG and BRAKE lights both come on to make sure you know there's a problem.
Your 85 alternator has an internal regulator, it sounds like your new alternator is bad.
Soylent Green sales
rock crawler
Yeah, an 85 with a 22R should have an external V reg.
Should be fairly cheap to replace.
Thats not true, my 85 truck that i just sold had a 22R and the alternator was internaly regulated. all trucks from 85 on have internaly regulated alternators.
Soylent Green sales
rock crawler
Thats not true, ... all trucks from 85 on have internaly regulated alternators.
No, that's not true.
22R's and external regulators went past 84. Especially on base model 2WDs.
1985 Toyota Pickup
Discussion Starter #8
yeah its internally regulated, i took thee alternator off and had it tested and the voltage regulator was bad, stator was bad, low voltage output, etc.. luckily the guy just handed me a new one and took the old one.
Soylent Green sales
rock crawler
Great. Glad you got it worked out.
I had an 85 base model 4x4 with a 22R and the alternator was internaly regulated.
1985 Toyota Pickup
Discussion Starter #11
thanks for the help
1 - 11 of 11 Posts
