Car Specs: 1985 Toyota Pickup--22re EFI--2.4liter--Manual 4 speed--165k miles (bought it in 2017 with 93k)
Oil & Gas (if it matters):
Gas (usually 87 octane, just splashed out on 92 to give the truck a treat and clean out the gunk...ironically just before this trouble started)
Oil (usually 15-40, but tried 20-50, as I heard that might slow the amount of oil I burn/leak...back to 15-40 now to see if that was causing my sluggish starts). I also give a few squeezes of Lucas ever 1k miles or so.
Problem: About a week ago the car started having a hard time starting. Engine would keep trying to turn over, but really struggle for anywhere from 3 to 10 seconds before eventually starting. When engine is nice and hot it's slightly better, but still takes a few seconds to start. Note: up until a week ago car would start immediately upon key turning, no chugging what-so-ever.
Possibly (but I doubt it) related problem: The grey smoke that normally comes out for the first few minutes in the morning, now shows up throughout the drive even 30 minutes in, not like Spy Hunter style lol, but still enough that it's noticable when I am going slow, and I am sure there on the highway as well.
Note: Once the car starts, it runs perfectly fine, no skips/jitters/chugs/revs/misfires/etc. I never lose power, it runs smooth as silk...ONCE it has started. Hopefully that helps eliminate some of the problem areas that would still occasionally rear their head while driving.
What I HAVE tried/checked:
1. Air filter is clean
2. Coolant maintains it's full level for months
3. Oil - I burn/lose about a quart every 1,000 miles. Top up as needed. Some of that is probably burning out the tailpipe (although the smoke is white and sweeter, which makes me think antifreeze) and dripping off the engine where a previous mechanic cracked the timing cover (or some bolt near there).
4. Battery - Reads 12.8v when off, and 14.3v when on. Tested good at Autozone
5. Starter - Installed (by me) 2 months ago. Tested good at Autozone
6. Alternator - finally went on me earlier this year, put that in myself. Also tested good at Autozone
7. Fuel Pressure Regulator - A mechanic friend and I were very confident that was my problem after reading some similar symptoms from a fella here on ToyNation. So I bought one and installed it, no change in symptoms.
8. Fuel Filter - had no idea if this was bad, and symptoms didn't point to it, but since I had never replaced it (have owned the rig for 4 years and 70k miles), I swapped it while the FPR was off and I had more room to play.
9. Wiring to battery - I know wiring can be a culprit often times...I have a new heavy duty ground from negative battery to engine block about a year ago. also replaced the positive terminal and cleaned and re-did anything leading off the hot, all in good shape, at least anything that touches the battery (I haven't played with any other hots or grounds)
10. Cold Start Valve - I took this off, and put the Ohm tester on it, and it read 4.8 ohms, which I hear is right around what it should read. So I think that part is good.
11. Fuel lines - for what it's worth I followed them from the tank (as close as I could get) to the engine, and they seem in good shape with no kinks or damage, and the car runs perfectly fine once it starts, so makes me think fuel can flow fine once it's started.
Things I have NOT checked:
1. Fuel pump - mostly cause it's a PITA to drop the tank, and I am doing all these repairs from these auto-part parking lots (we live in our rig full time, so no homebase, lifts/jacks/huge tool sets, etc)
2. Throttle Sensor - mechanic friend said there is a very low chance this is causing my long start issue, since the car idles and runs perfectly fine once it's started.
3...probably a bunch of things I've never heard/thought of
So here I am, after a full days work (which I really enjoyed to be honest)...yet, I am $120 poorer (FPR + Filter), and the car still has trouble starting. Hoping there is someone out there who can point me in the right direction.
Huge love for all the help, and if I missed anything that would help the diagnoses just ask,
Mike
p.s. If anyone is interested here are a few photos of our rig that we've been living in for the last 4 years
Mike
