1 - 6 of 6 Posts
I just bought a 85 4 door hatchback Corolla. It's fwd. I was driving it home and started hearing a hard knock in the engine. It's blowing white smoke as well. Would you guys recommend digging into the engine and fixing it or just replacing it? I believe it has the 4AC in it. If you recommend replacing it, which engines would make for an easy swap?
Thank you for any help in advance.
· Administrator
マズダスピード3
You can drop the oil pan and check the connecting rods first. Then perform a wet compression check to see if there’s blowby.
From there, determine if you can source a replacement engine. Otherwise, you’ll need a machinist to check the engine tolerances.
I would drive it back to the seller and demand a reimbursement. If you didn't buy it knowing it had this engine problem but the seller knew it and didn't disclose it, you are legally entitled to nullify the purchase.
· One with the farce
Depends entirely on hearing the whole story, we’re only hearing a part of one side.
· Administrator
マズダスピード3
This is the risk one takes when buying a swap. Might be done professionally or half assed. That’s the roll of the dice.
Going back to stock will be tricky. Can’t source a good harness unless you find a donor chassis.
The OP didn't say the car he bought had a swapped engine in it. He did ask what engine would be best to swap in as a replacement for his current engine. At least that is how I interpreted the OP's initial post.
1 - 6 of 6 Posts
