Yeah I'm going to ask him about all that. I think it's been sitting about 4 years....so that could explain a lot of it too. Hell, could just be bad fuel! Although this guy is a good mechanic/4x4 enthusiast so I'm guessing he would've already looked into that. Anyway, worst case scenario, if I need head gaskets (probably wise to do timing chain, chain guides, tensioners, water pump, etc. at the same time) how much $ do you think I'd be looking at? Just wanna factor this into the worst case (or damn near worst case) calculation. Plan for the worst, hope for the best, right? Thanks fellas!With 200k I would be more interested on whay had been done to the vehicle!
Timing chain, head gasket, water pump, clutch, etc; if those items hasn't been done in those 220k, a good chance they would be needed some time down the road!
You need to take that into consideration as well!
The rough running issue could be cause by head gasket leaking, maybe?
Warm starting problem could be due to ignition system components.
If you don't mind dealing those issues, and the price is very good, then maybe...!
Yeah, carb is exactly what he thinks the issue is. And that's one very likely possibility....but from the reading I'm doing on this issue on these engines, it could be carb....it could also be wiring....or ECU....or sensors....or air leaks....or ignition....or IAC valve....or head gasket.....or timing related....or like 5 or 6 other things.If everything else has been tuned up, it’s probably the carb causing those issues. Spend a few bills and put a Weber 32/36 on it, good carb and easy to set up.
There’s minimal wiring, no iac and no ecu. The 22r carbs are notoriously crappy when old and worn, and trying to rebuild it will make you want to slam your head into a wall. Don’t buy a cheap aftermarket one either. This is all firsthand experience btw.Yeah, carb is exactly what he thinks the issue is. And that's one very likely possibility....but from the reading I'm doing on this issue on these engines, it could be carb....it could also be wiring....or ECU....or sensors....or air leaks....or ignition....or IAC valve....or head gasket.....or timing related....or like 5 or 6 other things.
Gotcha! I don't mind rebuilding it, but I wouldn't mind getting a little better performance than stock, and yeah, if I can save a ton of time and get a newer, more reliable part, maybe sell the old one to recoup some costs, that's a win. Sounds like the Weber is the way to go eh?There’s minimal wiring, no iac and no ecu. The 22r carbs are notoriously crappy when old and worn, and trying to rebuild it will make you want to slam your head into a wall. Don’t buy a cheap aftermarket one either. This is all firsthand experience btw.
Yeah I got a FSM for my Land Cruiser....that thing it's worth its weight in gold! Will prolly do the same for this and/or Chilton.That’s great, good deal too I think. You’ll have fun with it! Pick up a repair manual for it though, it’ll be the best mod you can buy 😂
Gotcha...but after all that, whether it's a mechanical feedback system like in a carb, or a computer feedback system in an EFI, all the actual engine "sees" is a boom, that is defined by air, fuel, and spark. So unless the EFI is calibrated incorrectly and getting the air/fuel/spark mixture totally wrong (in which case I'm guessing the vehicle wouldn't run very well, which doesn't seem to be the case for most installs), I don't see how the boom from an EFI system could be worse for your engine than the boom from a carb system. All the processing or feedback or systems before the fact are kind of irrelevant as far as the engine itself is concerned, right? Again, all the engine "sees" in terms of wear and tear associated with a carb or EFI is combustion in the combustion chamber....or am I missing something? Again, limited knowledge of these systems. I know enough to know I don't knowMy understanding of fuel mapping, it is basically a chart that contains fuel control info to help the ecu with the injector control!
At this rpm, coolant temp, etc this is the amount of fuel needed; an overly simplified setup! Basically, on a feedback fuel control system that is capable of learning, it takes a bunch of sensor inputs and outputs, stored them into a chart, so it can refer back to control the fuel injectors.
