1 - 3 of 3 Posts
I have replaced the front driveshafts on this since it was new in 1986 without a problem - pop them out with a lever,however now I have the new driveshaft for the left side (they are both identical on the diff end)inadvertenly stuck by the "C" clip in the right side of the diff.
Removing the the diff.front cover plate there is not enough clearance to get the "C" clip off the end splines with a screwdriver and as much force has been applied to the shaft as I want to without damaging the Diff.housing.Short of trying to dismantle the centre spigot of the diff. drive gears has anyone run into this before and has some suggestions.
Any help at this time would be appreciated.
1 - 3 of 3 Posts
