The rear brakes on my 1987 Cressida (disc brakes) have (all of a sudden) started failing to release completely. This means they are dragging and becoming red hot (the front brakes have no problem). Yesterday, I removed the rear calipers, inspected them, (did not disassemble them), and finding no obvious problem, pressed the piston back in, then replaced them, then replaced the brake fluid in the car, flushed the brake lines completely (bled brakes on all four wheels). I should note here that the brakes fluid coming out of the rear lines was quite dirty, (the front lines were not so bad)..I flushed them until the fluid coming out was clean. Then I drove the car again. The problem was still there! Now, I can go ahead and replace both calipers, but would this fix the problem? Why would both calipers start dragging AT THE SAME TIME? Could the problem be further up the line (either with the master cylinder or in the lines between the master cylinder and the rear brakes?) When I bled the brakes, the fluid flowed fine. I should also note this car doesn't get driven allot (it sometimes sits for as much as two weeks at a time without being driven at all...this problem started to occur immediately after a two-week period of inactivity). Anyone have any ideas???
