22RE ENGINE
Hi there i bought two older yotas one is a 88 and ones a 87
to make long story short. I took the 22re motor out of the 87 and placed it in the 88 body now im having hesitation troubles when driving and shifting.. The motor idles ruff untill warm also then you give it gas ect then smoothes out at higher rpm in PARK.. But under load it seems i have no power unless i let off the gas abit and it gradually picks up rpm once the rpms is up the truck has good power and seems to drive well untill you change gears ,then it seems like the motor is fighting against it self ,, but if you rev it in park it seems ok ect... Am i having fuel pump pressure problems?
* when putting the motor in i took the wiring harness from the 87 and the computer too only thing i see different is the location of the oxygen sensor,
Any ideas or help would be greatly appreshiated.
AND YES THE CHECK ENGINE LIGHT IS ON AND I DONT KNOW HOW TO CHECK THE OBD DIAGNOSTICS system.. I cant find the terminal plug to check it..
one other thing is i unplugged the oxygen sensor it really didnt make a difference.. It may seemed to idle a bit smoother unpluged..
I also checked the vacuum advance in the distributer it seems to be working fine.. The only thing would be the mass air flow sensor that is still from the 88 and not from the 87 and by the looks of it does look quite bigger and different...
I know this may sounds confusing ect and a waste of time but im so close to getting this truck up and runnin good i can taste it
See when im done i would have made one very good truck cheap with loads of parts for about 500 bucks which the body is mint so you see my point..
HELP lol
HELP lol
