I've run mine right out of gas with no ill effects. Check the compression across all four cylinders, should be up above 170psi. 150 is okay, but is in the range of "Needs service!"
Could be low oil pressure... My Geo used to knock when it would run low on oil or if pressure would fall. I would do the oil and use a real oil pressure gauge instead of the "idiot light" in the dash. Actual pressure should be around 100psi in a healthy engine, at least for the Suzuki G16. Not sure on the 3sfe.
