I’m leaking coolant and I’m not too sure where from. I’ve been under to look at it drips off of the oil pan right along the seam. Wondering if anyone else has had this problem or if anyone knows a possible reason
You just have to go 'up' from the leak and find it. The water pump will leak inside the timing cover and can be a bit of a pain to find. If the water pump is leaking, that means the bearings are bad and it needs a replacement (along with any timing components that got wet with coolant).
-Charlie
1 - 4 of 4 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
