I replaced the oil seal and the oil pump gasket, and no my car runs really bad. It seems like the timing is off, but I have checked it like 5 times. The notch on the crankshat lines up with the oil pump at TDC, and the notch on the camshaft gear lines up with the notch on the camshaft case. I did not mess with anything else. Before doing the work the car ran fine.
What could be the issue? Timing? If it is I don't know where I went wrong.
Thanks for you help,
Luckybob
Luckybob
