just bought my second corolla. however, this one has come with a few issues.
to start off, i have this issue where, if my fuel tank is reading a quarter tank and i happen to be braking downhill, the car will shut off. i have to put it in park and start it again. i've learned to be very careful about keeping my fuel levels high according to the gauge. i have this notion that it may be the fuel sending unit but i'm not 100% so, here i am.
the second issue i've noticed is a very bad stuttering when i want to take off. i'll put my foot on the pedal to accelerate and it stutters and almost goes nowhere until "realizes" that i want to go and it catches up. when i finally get it going, it drives fine; it's getting it to initially accelerate that's the issue. i have my suspicions of this as well as i pulled a few spark plug tubes and found oil in them. i'm thinking this might be an issue OR i also think it could be the fuel pump. i've ordered new spark plugs, wires, rotor cap, and valve cover gasket with spark plug seals and grommets in hopes that it'll help the issue if not fix it. (i need to do a tune up anyway). if anyone has experienced these symptoms, your input would be greatly appreciated. i haven't ordered the fuel sending unit or fuel pump because i'm doing one thing at time, in a sense.
third issue i'm having is with my wheels. i bought the rolla with aftermarket wheels. they appear to be 15x8 and no matter where i go, i scrape BAD. i'm wondering what you guys are running on yours. i have done a little research and found that i should be running 15x6.5 with a +35mm offset? the wheels on it now have a 0 offset.
last issue, and this is more cosmetic than anything, is the sunroof. it wasn't working when i bought it and i'm trying to get it to work but toyota has discontinued all parts but the drain hose. does anyone know of another way that i could repair the sunroof or if there's an aftermarket option. ideally, i would love to find a glass sunroof instead of a metal panel because of the rusting (which the current sunroof has) but, as long as i could get it going, i would be happy.
i have many plans for this little thing but for now, i just want to enjoy it as a stock sedan.
