1 - 6 of 6 Posts
G
The leak is not at the reservoir. I took quick look and do not immediately
see the pump.
Please, where is pump located and how difficult to replace it or the high
pressure hose.
Thank you,
Seamus J. Wilson
G
Discussion Starter · #2 ·
seamus, the pump is located under the intake manifold to the rear of the motor, it is easily replaced from under the car have a
good day
"Seamus J. Wilson" <[email protected]> wrote in message news:[email protected]
> The leak is not at the reservoir. I took quick look and do not immediately see the pump.
> Please, where is pump located and how difficult to replace it or the high pressure hose.
> Thank you,
> Seamus J. Wilson
G
Discussion Starter · #3 ·
double check the leak source.
high pressure hose maybe leaking and dripping down on the pump.
try observing area with engine running and turning wheel to one side and
keep a slight pressure on steering wheel in locked position, that should
cause the pressure increase and show the leak source.
I was told my pump and rack was leaking, found high pressure hose had a
small leak under pressure. Hose replacement can be a DIY if you have jack
stands, floor jack, assorted metric wrenches.
Note: Your high pressure hose maybe in two sections. The hose is part
rubber and rigid tubing. hose repair is not recommended. the hose
assembly is sold at most auto parts shops.
Good Luck.
G
Discussion Starter · #4 ·
Thank you for the kind answers.
Merry Christmas to all,
Seamus J.
"jjjsan" <[email protected]> wrote in message
> Good Luck.
G
Discussion Starter · #5 ·
"Mark Miller" <[email protected]> wrote in message
> motor, it is easily replaced from under the car have a good day
>> pressure hose.
>> Thank you,
>> Seamus J. Wilson
Hi all on group.
I had a leak like you describe some months ago.
It seemed to be from the Steering pump area.
I got it checked out at a local shop so one could look underneath.
they confirmed the pump.
But I still had a full Steering fluid reservoir.
I took samples of fluids from the car.
1 clean drip from leak.
1 from dipstick engine oil
1 from Power steering reservoir
1 from Brake fluid reservoir
1 from Auto Box dipstick.
and compared them.
IT WAS ENGINE OIL by a mile.
I cleaned all the area between firewall and the back of the 4.
with a good dose of GUNK.
And the leak was from the back left hand corner of the Rocker Cover.
It was seeping on to a protruding fitting then going over it
and running on to the steering pump.
It was very difficult to see.
Mirror and bright light helped.
On MY 4 cyl 1995 2.2 CAMRY
The rocker cover & gasket is held down with 4 X 30 mm nuts on the top
of the Spark Plug tubes.
I took these up half a turn and it cured the leak..
I now have a new gasket but the leak has not turned up again.
So its not been fitted yet.
Maybe this helps you.
Johnny UK.
G
Discussion Starter · #6 ·
Thank you.
Seamus J.
"JM" <[email protected]> wrote in message
>>> high pressure hose.
>>> Thank you,
>>> Seamus J. Wilson
> Hi all on group.
> and compared them.
> Johnny UK.
1 - 6 of 6 Posts
