My current condition is that the brake pedal goes nearly to the floor when braking. The brakes are working, but it is dangerously too close to the floor.
A few years ago I replaced the rotors with new Brembos. I noticed they were thinner than the originals. The seller told me to add shims to the pads. I did this, but the brake pedal travel went closer to the floor than normal.
This winter I has a leak. I replaced a line. I've bled the brakes rear to front, RR-LR-RF-LF and LR-RR-LF-RF, and also bled the master cylinder. I repeated this several times. I have speed bleeders on the cylinders.
Does anyone have any ides on what I might try to get a higher pedal when braking? They don't seem spongy as much as they are just too low. I also checked the brake pedal distance to floor in the up position and it is within specs.
Rotors and pads all have less than 1000 mi. on them.
Thanks!
Thanks!
