After experiencing a noticeable amount of engine misfire, I set out to replace the spark plugs/wires, distributor cap/rotor on this vehicle (my first time undertaking such a repair). I picked up a new cap, rotor, wires, and standard spark plugs (instead of platinum plugs). Halfway through the job, and after inadvertently pulling off all of the wires from the distributor cap, it became clear that replacing the rear plugs/wires was beyond my DIY capability as they sit under the plenum. I looked up the correct firing order online (1-2-3-4-5-6) and decided to replace only the front three plugs/wires, including the wire that runs from the middle of the cap to the ignition coil (the roughly inch-long metal clip on the old wire that connected to the coil had been worn down to a little nub), and then reinstall everything. Now the engine cranks but won't start.
What could be causing this and how do I go about fixing the problem?
Engine Size: 2.5L V6
Mileage: 55300
Mileage: 55300
