1 - 4 of 4 Posts
1993 toyota 4x4
just installed a 3" body lift and now a/c compressor wont come on,,wires are good and secure, and the green light comes on the a/c switch,,,but no compressor,,,,,any ideas on where to look now???? thanks in advance folks!!!
· Cressida nut
91 Pickup (Hilux)2wd
check the pressure switches in the lines, make sure you didn't pull the wires off those either.
· Soylent Green sales
rock crawler
Its cause you installed a body lift.
Check a ground.
X2
Most likely ground wire broken by the BL install is the one from the firewall to rear of the engine.
1 - 4 of 4 Posts
