Status
Not open for further replies.
1 - 12 of 12 Posts
03 CAMRY XLE
There is a fusible link between the battery and the 100 A alternator fuse, but usually you will find another faulty fuse first. Have you tested the voltage at both sides of the alternator fuse? ...Suggest that you inspect other fuses like 30A AM2, 40A Main, 5A starter, Ignition etc. ... Will probably be one of those.
Reactions: loriannp17
1995 Camry LE Wagon
Do you have an owners manual?
I think what you're looking for is the big 30a fuse in Junction Box 2, that's the front box closest the bumper, DS. The fuse looks like it can be pulled out, but it needs to be unbolted from underneath. There are 3 medium current fuses in line #1,2,3 (40,30,30 amp) at that location. You'll need to disconnect the fuse box to get at it. It is clear plastic but visually it may not look blown. Use a flashlight to look closely at it.
Discussion Starter · #4 ·
We have changed all fuses and the 100 amp alt fuse. Have the owners manual. Trying to locate the fusible link. The car is completely dead. Won't crank. He changed the alt. without disconnecting the batt. GRRRR
03 CAMRY XLE
No crank sometimes is an indication of a problem with the Neutral Safety Switch. Take the gearshift, ignition to ON, and move it up and down several times, and then turn switch to Start, like you are going to start it. Listen for any noise or click. If you hear anything at all ...it's probably the NSS ... just needs cleaning.
03 CAMRY XLE
If the NSS is defective, it won't crank. On my '98, I had a frozen shifter like you are talking about, but unlocked it like you are saying, and drove it for two years or so, and then had to eventually remove the NSS, disassemble it, clean all contact surfaces, spray with contact cleaner ... Add new dielectric grease. ...This was due to a no start after driving through a rain puddle. Took two hours or so. ... Can't conclusively say what is wrong with yours, but guessing that NSS needs cleaning. It's time for it. Maybe it's just a coincidence that it happened at the same time as the new alternator.
http://www.toyotanation.com/forum/1...ral-safety-switch-cleaning-5.html#post8341521
03 CAMRY XLE
Locate the 40A AM1 fuse. You have to use a volt-meter or a test-ight to check for 12v on either side of this fuse. If you get 12v on either side of that AM1 fuse, then the fusible link is good ... not burned out. The AM1 fuse is located below the dash to the left of the steering column. Pull the fuse and test each of the fuse terminals for 12v.
... There may be a panel to remove.
· unofficial TN member
2020 camry xse 2gr-fks
you might have covered this already but if there is ZERO electrical response, how do you know if the + and - battery terminals are good? was the battery recently tested or replaced prior to replacing the alternator? when was the last time the car ran?
i have had both + and - terminals either corroded out or the actual terminal clamps get stretched just loose enough they weren't making contact after a random impact, like closing one of the car doors.
1 - 12 of 12 Posts
Status
