1 - 4 of 4 Posts
hello, my starter wil click a few times then sometimes start. already replaced the battery. how hard is it to replace the starter? i have the v6 4x4 it looks hard to get to the one bolt.i think it takes a 14mm. well got the starter out wow what a job. i had a manual bit it didnt tell u there was a bolt on one side of the starter and one on the other,anyways all is well
20 Toyota (NipponDenso now called Denso) starter repair sites:
http://www.off-road.com/4x4web/toyota/tech/starter/ -
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
http://char.tuiasi.ro/vw/reality/rogerb/4x4/CheapTricks/Starter.html
http://yotarepair.com/startercontacts.html
http://www.toyotaoffroad.net/afertig/88/starterrepair.htm
http://www.4x4wire.com/toyota/maintenance/starter
http://www.yotatech.com/~corey/tech/haveblue_starter/haveblue.htm
http://www.sleeoffroad.com/technical/tz_starter_rebuild.htm
http://www.startercontacts.com/install.htm
http://www.startercontacts.com/images/OSGR_Exploded_view.jpg
http://www.colorado4x4.net/tech/starter_contacts/starter_contacts.html
http://www.barneymc.com/toy_root/techneek/starter.htm
http://perso.wanadoo.fr/adherence.4x4/start_bj.htm
http://www.automotiveforums.com/vbulletin/showthread.php?t=166530
http://www.toyotanation.com/forum/showthread.php?threadid=27312&forumid=10
http://www.toyotanation.com/showthread.php?threadid=27312&forumid=10
http://www.toyotaoffroad.com/Articles/Projects/starter/starter.htm
http://www.tacomaterritory.com/boophoenix/starter.html
http://www.tacomaterritory.com/boophoenix/starter/image01.jpg
http://www.team-integra.net/sections/articles/showArticle.asp?ArticleID=1079
http://personal.utulsa.edu/~nathan-buchanan/93fsm/starting/1starter.pdf
Starter contact kits (8mm ID hole):
Ace Electric # S-5263 (only two contacts)
Ace Electric # S-5264 (only two contacts)
Metro # 66-82104 (only two contacts) (www.metroautoinc.com ,Pomona,California)
Toyota # 28226-72010/80 (battery side)(also1KZTE-2LT-1KZT)
Toyota # 28226-72080 (8808-9108)
Toyota # 28226-16130 (9108-9308)
Toyota # 28226-55050 (9308-9511)
Toyota # 28226-70040 (9308-9511)
Toyota # 28226-72040 (motor side if needed)
Toyota # 28226-72010 (8808-9511)
Toyota # 28226-74070 (9108-9511) (2000 Tundra & others)
Toyota # 28226-22050 (2000 Tundra & others)
Toyota # 28226-66060 (1993-1997 Land Cruiser 2.0 KW starters)
For others besides 22R series:
Toyota # 28226-54220 (motor side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130,LN108,112,85..4FC)
Toyota # 28226-54250 (Diesel Surf 2.4TD, contains a new end cover and gasket)
Toyota # 28226-54320 (battery side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130, LN108,112,85..4FC,3B-1HZ-BJ73-HZJ7#-1KZT-KZJ70)
Toyota # 28226-17030 (battery side) (1H#-HDJ80-HZJ80)
Toyota # 28226-56250 (battery side) (3B-1HZ-1PZ-PZJ7#)
Starter contacts only (8mm ID hole):
Ace Electric # S-5231
Ace Electric # S-5293 (crescent moon shape)
Ace Electric # S-5295 (crescent moon shape)
Metro # 66-82106 (www.metroautoinc.com ,Pomona,California)
Tons more at:
http://www.metroautoinc.com/PDF File/66-Denso Solenoid Contact.pdf
Wilson’s Electric # 45-29-652 (maybe it’s 45-29-6521)
Starter brushes:
AC Delco # D762
GP Sorensen # 255048
Standard # JX-117
Whether your starter uses two rectangular types or one rectangular and one crescent you can substitute with two squares or one square and one crescent so any of the above part #'s for those kits will be the right ones,or about half of the auto electric shops in your local yellow pages would sell aftermarket contacts for only $5 each or the pair.
If the brake and charge lights come on during revving of the engine then it's a sign that the carbon alternator brushes require replacing as this is the mileage for them to wear out. In alternators the brushes wear out on average every 140-170 000 miles where on the dashboard the brake & charge light both come on at the same time. About half of the auto electric shops in your local yellow pages sell carbon alternator brushes and copper solenoid starter contacts for about $5/pair.
Another way to verify that the alternator is not charging is while the engine is running bring a metal screwdriver or any metal object near the alternator and if the alternator is working properly then it should act like a magnet and grab the screwdriver.
For carbon brushes R&R:
http://www.4x4wire.com/toyota/maintenance/alternator_brushes
http://www.toyotaoffroad.net/afertig/88/alternatorbrushes.htm
http://perso.wanadoo.fr/adherence.4x4/alternateur_kzj.htm
http://www.automotiveforums.com/vbulletin/showthread.php?t=166525
http://www.toyotanation.com/forum/showthread.php?threadid=27270&forumid=10
http://www.pirate4x4.com/forum/showthread.php?s=&threadid=26734&highlight=alternator+brush+holder
http://www.bitwalla.com/cruisers/articles/alternator.html
http://www.barneymc.com/toy_root/techtalk/electric/altrnatr.htm
For decoding the dashboard lights:
http://www.powerbase-auto.co.uk/alternator_faults.htm
http://members.1stconnect.com/anozira/SiteTops/energy/Alternator/alternator.htm
Here are part #'s for Toyota alternator carbon brushes and copper solenoid starter contacts which are used in about 95% of all Toyota vehicles.
Toyota alternator Brushes with holder:
Toyota # 27370-35060=$29 CDN
Honda # 31105-PZ1-003
Metro # 39-82003 (www.metroautoinc.com ,Pomona,California)
Unknown brand name # F4019-53035
Alternator brush only (qty:1 brush unless otherwise stated):
AC Delco # E724
AC Delco # E731 (side wire and concave tip)
Ace Electric # DA-61 (brush only),S-5367 (brush holder)
Beck Arnley # 178-1669 (side wire and concave tip)
Beck Arnley # 178-1376
Borg Warner # X580 (side wire and concave tip)
Canadian Tire # 19-2050-6=$4.49/pair
Daihatsu # 27370-87302-000
Daihatsu # 27371-63020-000
Daihatsu # 27371-87501-000
Daihatsu # 27371-70300-000
Echlin # E601=$8.16 CDN/pair (UAP/NAPA)
Echlin # ECHE601
Echlin # EC480
Echlin # ECHE480
GP Sorensen # 255047 (side wire and concave tip)
GM # 94123056
GM # 96054118
Honda # 31144-PD1-004=$9.72
Honda # 31144-PD1-0040
Honda # 31144-PD1-0030
Honda # 31150-PR7-A01
Honda # 31150-PTO-003
Hino Industries # 021660-0390
Hino Industries # 021660-0510
Isuzu # 8-94123-056-0
Isuzu # 8-97032-308-0
Isuzu # 8-97032-310-0
Mazda # 021660-0390
Mazda # 021660-0510
Mazda # KL47-18-W75
Metro # 38-82001(side wire concave tip) (www.metroautoinc.com ,Pomona,California)
Mileage Plus # E601SB
Mitsubishi # MD604474
Mitsubishi # 21660-0510
Niehoff # WA571 (side wire and concave tip)
NipponDenso # 021660-0390
NipponDenso # 021660-0510
Standard # JX-116 (side wire and concave tip)
Subaru # 021660-0390
Subaru # 021660-0510
Suzuki # 31631-82610
Suzuki # 31656-82611
Suzuki # 021660-0510
Toyota # 27370-42010
Toyota # 27370-75060
Toyota # 27371-63020=$5.80 (up to 9105) (side wire and concave tip)
Toyota # 27371-70300=$5.20 (9105-9511)
Toyota # 27371-76004-71
UAP/NAPA # MPEE601SB
Victory Lap # FAX57=$4.49 CDN/pair (Canadian Tire)
Wilson's Electric # 26-29-7534 (side wire and concave tip)=$2.20 each CDN (Diesel Auto Electric)(Parts for Trucks,box of 10 for $3.40 CDN)
Specifications:
Length=15 mm
Width=7 mm
Thickness=5 mm
Lead length=49 mm
These Honda alternators are the same except the pulley must be swapped:
1986-89 Honda Accord (Carb),the EFI can be used but the voltage reg must be swapped
1990-93 Acura Integra
For alternator upgrade:
http://www.off-road.com/toyota/tech/100alt/index.html
http://www.4x4wire.com/toyota/tech/alternator
http://home.earthlink.net/~twopapa/bigalt.htm
http://www.toyotaoffroad.com/Articles/Projects/Chevy_Alt/Chevy_Alt.htm
http://www.alternatorparts.com/Toyota_highoutput_alternators.htm
Any Public Library in your area would have the Factory service manual, Haynes,Chiltons,Mitchells,Clymers, Bentley and Toyota repair books.
Free AutoZone service manuals at:
http://www1.autozone.com/servlet/UiBroker?ForwardPage=/az/repair_info/repair_guide/repair_guide.jsp
Tons of free factory service manuals for 4-Runners,etc:
http://www.ncttora.com/fsm/index.html
http://rapidshare.com/users/4NH9R4
http://forum.ih8mud.com/showthread.php?t=128021
http://www.babcox.com/editorial/ic/ic110028.htm
Free 1985 Toyota 4-Runner & pickup Factory Service Manual:
http://www.functionalfab.com/resources/toyota 4runner.pdf
http://www.ncttora.com/fsm/1985/1985FSM.pdf
http://www.muchadoproductions.com/info/xxx1985toyotatruckfsm.pdf
http://www.truckporn.com/tech/FSM/Toyota/1985fsm.zip
http://s3.uploadline.com/d/4831811/1168232885/1985fsm.zip
http://www.lukemiller.org/toys
http://www.subliminaltrips.com/1985toyotatruckfsm.pdf
Free 1987 Toyota 4-Runner Factory Service Manual:
http://rapidshare.com/files/34005580/Toyota.4Runner.1987.1998.SIL.MMedia.RUS.part1.rar
http://rapidshare.com/files/34006565/Toyota.4Runner.1987.1998.SIL.MMedia.RUS.part2.rar
Free 1988 Toyota 4-Runner & pickup Factory Service Manual:
http://granolaboy.net/temp/toyota_truck_and_4runner_88.pdf
Free 1990 Toyota 4-Runner Factory Service Manual:
http://rapidshare.com/files/34006966/Toyota.4Runner.1990.1995.SIL.rar
Free 1993 Toyota Pickup Service Manual:
http://www.ncttora.com/fsm/1993/index.html
http://www.ncttora.com/fsm/1993/1993.zip
http://www.snjschmidt.com/wiring
Free 1995 Toyota 4-Runner Factory Service Manual:
http://www.the-roo.com/4runner (3VZE engine, 3 liter, V6)
Free 1996 Toyota 4-Runner Factory Service Manual:
http://rapidshare.com/files/34004224/Totota.4Runner.1996.2002.SIL.rar
Free 1998 Toyota 4-Runner Factory Service Manual:
Free 2002 Toyota 4-Runner Factory Service Manual:
http://rapidshare.com/files/34007037/Toyota.4Runner.2002.Audio.SM.rar
Free 2006 Toyota 4-Runner Factory Service Manual:
http://rapidshare.com/files/34007101/Toyota.4Runner.2006.SIL.rar
1996 Toyota Tacoma Factory Service Manual (2)(3)RZ-FE 5VZ-FE:
http://www.ncttora.com/fsm/1996/96_repair.zip
http://www.ncttora.com/fsm/1996/images/index.jpg
1998-2000 Toyota Tacoma Factory Service Manual 5ZE-FE:
http://www.ncttora.com/fsm/2000/index.html
http://www.ncttora.com/fsm/2000/2000_FSM.zip
2003 (years: 2001-2004) Toyota Tacoma Factory Service Manual (2)(3)RZ-FE 5VZ-FE:
http://www.deserted1.com/FSM
http://www.ncttora.com/fsm/2003/index.html
http://www.ncttora.com/fsm/2003/2003_FSM.zip
2005-2006 Toyota Tacoma Factory Service Manual 1GR-FE & 2TR-FE:
http://www.ncttora.com/fsm/05+/index.html
http://www.ncttora.com/fsm/05+/05+_FSM.zip
Free 1989 - 1995 Pickup Mitchell Service Manual:
You can download the winrar archiver from: http://www.rarlab.com/download.htm
And The ISO file can be downloaded from:
http://www.filecrunch.com/file/~ga05yg <--- Part 1
http://www.filecrunch.com/file/~tlgobs <--- Part deux
The two rar files are 90 Megabytes in size, but once unrared it is a 300 Megabyte ISO image.BTW: File will be removed automatically if there is no download for 30 days.
FSM (factory service manual) & owners manuals can be acquired in several ways:
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton, CA 90220-5538
USA
Ph:1-800-622-2033 (outside CA)(M-F: 7-5 PST)
Ph:1-800-443-7656 (inside CA)
Ph:1-310-818-4630 (in or outside CA)
Speak to Beverly or Deloris
http://techinfo.toyota.com/public/main/mdc.html
http://www.4crawler.com/4x4/FSM.shtml
1)buy a used one off e-bay
2)some Toyota dealerships may give you one or sell it for $10-20 (used) as most Toyota dealerships don't repair many old Toyotas and no longer need the service manual
3)some public libraries sell their old books as they are not in demand any longer
4)some free buy & sell classified papers, websites and bulletin boards may have some used ones for sale
5)some junk yards may have one laying around
6)some Toyota specialty garages may have one laying around and no longer use it as the vehicle may be too old and those mechanics probably have so much experience that they could publish their own factory service manual with corrections and "real world repair tips"
7)if someone has the FSM maybe they could scan all of the pages and post it on a site for all of us to download or view.
:worship:
Sidney® ™
Repairs TV's,VCR's,home/car audio out of my apartment
E-mail:sidneybek(at)yahoo.com
Dartmouth,Nova Scotia
Canada
:kingme: for I am :canada:
check those starter solenoid contacts, they are usually the culprit and are only like $5. easy fix when starter is out of truck too. give it a shot, Sidney posted up great links to get you going. Sidney your info is greatly appreciated!!
JT
1 - 4 of 4 Posts
