Hi all. I know the topic has been discussed before, but also could not find anything specific regarding valve adjustment. No videos or anything. Maybe a couple of 3sfe videos.
I have read a few times that if you have no problem, you should not touch it, even read somewere that the valves on this engine almost never require adjustment (would explain the lack of information and diy videos).
Should mention that i have no problems eather, runs smooth, no noise, it is one of the quietest engines i know. In all manuals it says inspect and adjust every 96000km. I've done more than that, since i have it. Have not checked them, i suspect previous owners did too. It has arround 550000km, by my estimate.
The service company i worked in, a few years back, had a history of it for a head gasket job and head reconditioning (but not full), some 16-17 years ago, and half the mileage.
Just curious, i have a TB job in near future. Should i even bother ispecting valves?
As i said works like a clock on petrol and LPG also. Never had engine problems (knock on wood), except the normal oil pump gasket leak.
Cheers
Sent from my SM-J530F using Tapatalk
Cheers
