1994 amp install
1013 Views 6 Replies 6 Participants Last post by  CrazyCamry
anyone know about where is the best place to wire
the amp power wire through the firewall?
i dont know where to look for a hole. i saw the other thread, but thats
in a '99 and i have a '94
i cant find a hole, and i dont even know where to look.
could anyone also show me where the hole ends up in the
engine bay and in the interior?
thanks
1 - 7 of 7 Posts
http://toyotanation.com/forum/showthread.php?t=171673
Check this thread out and if you still need help, post again and I'll help you out. The veteran members usually don't like to answer questions twice if its already been discussed before.
you take off the wheel and take off the lining of the wheel well and you and get the power through :thumbup:
this is tooo much work
drill a hole.
this has been cover plenty of time.. search
next to the brake booster thing there is nothing which is a good spot to drill a hole if you get up under your dash and look theres nothing
idono1301 said:
...i cant find a hole, and i dont even know where to look.
thanks
Most men don't...:lol: Seriously, you can drill a hole in the firewall itself, just under the brake bootser and pull the wire through that way, but make sure you silicone the hole and/or use a rubber gromet to keep the metal from cutting through the wire and to inhibit rust...
i just didnt want to drill a hole in my car
and my way only took like 15 minutes so w/e floats your boat
You could always use the hole in the firewall where the wiring loom goes in. In my cabbie, its just above the fuel filter on the left of the Diagnostic plug.
1 - 7 of 7 Posts
