1 - 2 of 2 Posts
I recently got some great info on a problem with my T100 in this forum...the transmission won't shift into gear. I was instructed to check the neutral safety switch. OK...I guess I am having a senior moment when I look for it, because I cannot find it. The pics I found online show it on the side of the engine where the battery is located, but I guess that must be a different vehicle from mine, because I cannot see it. Could someone please direct me where to look to find the switch? Is it on the driver or passenger side of the transmission or mounted on the engine itself? A diagram or picture would be most appreciated but even a description would help. Thank you so much for your assistance! :)
1998 T100 SR5 2WD
If you follow the shift linkage from the shifter to the engine bay to the transmission, you should be able to find the NSS located on the right (passenger) side of the transmission. It is not located on the engine. ;)
1 - 2 of 2 Posts
