1 - 10 of 10 Posts
Hey...hi. My oil pressure sending unit leaks and needs removed. It has a plastic collar that a normal wrench does not fit. It looks like it requires a special socket (worth more than the sensor itself)....Has anybody have any tricks up their sleeve for safe removal by other means....vice grips and a hammer as an example??. I don't want to strip the threads in the block or snap the unit into two pieces. I tried various sealants to seal the leak, but with no success. No mechanics that I have contacted had the proper socket......they all just say "bring it in, we'll take a look at it"....yeah, I've already looked at it, and I didn't charge myself $90.00 per hour! Any tips at all would be appreciated. Thank you......and, do I have to remove the radiator?
Senior TN Member
Porsche
Clean off the sensor really well. Unplug it and use carb-cleaner and clear out area between plastic ring and block. You’ll see flat sides of a nut that you can fit socket over. I think it’s 18 or 19mm or some such.
The part next to the block is metal and an ordinary 6-point deep socket of the appropriate size will fit just fine. It's pretty big, twenty-something millimeters I think. The pipe-threaded part that screws into the block is not very big, maybe 10mm or so, and it should come out without much force.
Hey...hi. Thanks, everyone for your input. There was a design specific, oil pressure sending unit, thin walled socket, with the indented grooves that I required, at Canadian Tire. It was less than $12.00, so I bought it....I'm content now...lol. I'm still not sure if there is a steel shouldered nut behind the plastic ring or not. Either way, I'll post a picture with the socket number and my old sensor, when I get my new sensor (had to order it from NAPA).....the unit was cheaper than the socket...haha
Senior TN Member
Porsche
Weird. Should have regular hex nut on it to remove easily.
Let's see picture of the one on your car. And replacement unit.
The attached image is the factory unit on my car. You can see indents where the points of a six-sided nut would be on the metal part, which I think is what you're describing. I've had mine off and back on a couple of times with an ordinary deep well socket, but $12 for a specialty tool sounds fair enough.
Discussion Starter #9
You are probably correct. I think my sensor is original....the aftermarket ones have square shoulders. I just didn't want to take any chances. I didn't have a proper socket of the correct size anyway. Still waiting for my new sending unit to arrive, but I'm off on a fishing trip for the next week. I will post pics of my sensor and socket when I return. Thanks.
Discussion Starter #10
Hi...sorry to be tardy. Yeah, both my switch and socket seemed a bit strange. A standard socket or wrench would not grab the shoulders and there was no room for vice grips or such. The replacement took a regular 7/8" deep socket
1 - 10 of 10 Posts
