you can safely do a power flush, just make sure they use some decent quality fluid (not generic Dexron-III dino) like Castrol IMV synthetic blend. it's pricey though, complete power flush takes 12 quarts of fluid.
or as suggested above, you could do a few drain and refills at short intervals (e.g. every week or so), 4 times is usually enough.
it's still recommended to drop the trans pan and replace strainer (filter) and pan gasket.
