Hi all! The dome light of my toyota corolla won’t turn on. Tried to measure the voltage drop, it reads 5v (when the doors are open), it reads 8v (when the doors are closed). Does anyone know why this happened? Thank you!
Sorry I forgot to mention. Even from the wiring harness itself, I still get the same voltage drop. So I think the assembly is not the problem.Probably contacts in the switch - especially where the metal 'bars' are riveted to the dome light shell.
You can remove the dome light assembly, and see if you're getting a full 12V from the wiring harness connector.
And welcome to TN!
