Also when I stop and shut up the car then Start it back up, it will act normal.
Hello. Where is that located? On the front right?Can you disconnect the shifter and move the selector shaft on the transmission normally?
Welcome to TN!!!
Nope. He said he got it done by some backyard mechanic. The engine is great. No ticking. No smoke. I just would like an idea to start looking. Another idea is to just swap for manual. Idk. This was supposed to be for my son to start learning how to drive. But damn.It is most likely worth fixing
Did the rebuilder provide a warranty of any sort
I’m leaning more towards the neutral safety switch. I adjusted the cable and bolt and it engaged real smooth in reverse and forward but then it went away. It also had about 2qts over.If it needs a transmission swap you’d be looking at $1500-2000 plus the transmission. Unless you have adequate tools and are willing to take on the challenge. If you have another running car and can put this out of commission for a month it would be worth fixing. Too many people here have unreasonable and unrealistic yes understandable attachments to the Toyota name and will say this is worth fixing and I agree to an extent but only if you can do it yourself because paying for labor on this vehicle is just quickly going to be totaling up more than the vehicle is worth. But check the shifter cable linkage and hopefully the issue is minor. If the transmission was rebuilt by someone who knew what they were doing then it’s unlikely the transmission is failing again. But if the job was done by a jack you may have a can of worms / money pit on your hand. But I bet you could find a transmission for this car for $300-500 and then with 300-400 in tools you can get this job done. $600-1000, days of research and your own blood sweat and tears will be definitely worth it but unless you’re rich and have endless money to spend $2k plus for a transaxle swap will not be a good investment. Especially if it needs hubs and brakes which are easy repairs compared to a transaxle swap. But brakes and hubs together will likely be $1000 so you’re looking at $3k plus in labor to get it ship shape.
Why would you not fix it if the door bottoms are rotted out?The body on the car looks beautiful. If the chassis and floors are not all rusted out and the bottoms of the doors are not rusted out, I would definitely fix it.
Do tell what specialty tools will be needed that are 300-400?If it needs a transmission swap you’d be looking at $1500-2000 plus the transmission. Unless you have adequate tools and are willing to take on the challenge. If you have another running car and can put this out of commission for a month it would be worth fixing. Too many people here have unreasonable and unrealistic yes understandable attachments to the Toyota name and will say this is worth fixing and I agree to an extent but only if you can do it yourself because paying for labor on this vehicle is just quickly going to be totaling up more than the vehicle is worth. But check the shifter cable linkage and hopefully the issue is minor. If the transmission was rebuilt by someone who knew what they were doing then it’s unlikely the transmission is failing again. But if the job was done by a jack you may have a can of worms / money pit on your hand. But I bet you could find a transmission for this car for $300-500 and then with 300-400 in tools you can get this job done. $600-1000, days of research and your own blood sweat and tears will be definitely worth it but unless you’re rich and have endless money to spend $2k plus for a transaxle swap will not be a good investment. Especially if it needs hubs and brakes which are easy repairs compared to a transaxle swap. But brakes and hubs together will likely be $1000 so you’re looking at $3k plus in labor to get it ship shape.
The neutral safety switch just prevents the starter from running if you are not in Park or Neutral, and it turns on the reverse lights. Electronically, it doesn't control the transmission in any way, but the actual shaft going through it into the transmission does control the shifting. Anyway, you're on the right track checking that the cable is set correctly.I’m leaning more towards the neutral safety switch. I adjusted the cable and bolt and it engaged real smooth in reverse and forward but then it went away. It also had about 2qts over. View attachment 406847
I don’t understand where else to look. I will take apart the neutral safety switch and see what I can do. When I adjusted that cable, it shifted into gear so smooth. Then it went away. It wouldn’t go back into gear either in D or in R.The neutral safety switch just prevents the starter from running if you are not in Park or Neutral, and it turns on the reverse lights. Electronically, it doesn't control the transmission in any way, but the actual shaft going through it into the transmission does control the shifting. Anyway, you're on the right track checking that the cable is set correctly.
Yes I have and I let it warm up until basically the fan kicked on. It was way pass the hot line.The neutral safety switch doesn't control the shifting into gears. It's only mounted on the shaft that the cable uses to control what gear you're in.
Are you checking the level correctly? You should be checking it while the engine is running after slowly shifting through all the gears and back to P. If you check the level with the engine off it will appear high.
I need to know what is this. It’s loose. Is this part of the KickdownYes I have and I let it warm up until basically the fan kicked on. It was way pass the hot line.
Im talking about this line. In no way it’s connected to the neutral safety switch.That's the neutral safety switch. Like I said it doesn't control the shifting of the transmission. It only controls when the starter will work (Park or Neutral) and the reverse lights. Take it off if you want.
