1 - 3 of 3 Posts
My 1994 pickup seems to have play in the driveline. When I apply the gas and let off, it feels like a thump in the driveline. If i pack the slip yoke with grease, it's goes away for a little while until the grease is blown out. All the U joints are ok also. As a result, I'm starting to get a leak in the pinion seal. Any idea's out there?
could be a bad bearing in the rear end that has started the play and leak.
-Adam
toyota
i had the same problem, i changed the u joints on the front and back even though i didnt think it was them, and it ran fine until i locked the motor up
1 - 3 of 3 Posts
