1 - 4 of 4 Posts
Hey guys I’m new here but having this issue for some time now. Any help would be awesome! Want to thank you in advance. So here’s what I’ve got.
Everything worked perfectly and then I parked my yota and unfortunately battery died. I charged it back up and when I opened the door, the annoying steady ding and the running lights are on and key is in my hand. After doing research I changed the tail relay still dose it! Changed out the 10A fuse still does it! Just bought a new switch and installed it today. Still on no change.... So I’m at a loss here. I know I can always pull the fuse or relay for day driving. But the truck is for my 16 year old daughter and I want it back to opporating order. Any ideas? Anything will help at this point. Thank you again.
1998 T100 SR5 2WD
Welcome to the forums! :)
Do you have a trailer light adapter installed? Those are notorious fer causing electrical gremlins. Try disconnecting it and see if yer issue still exists. ;)
No I don’t have a trailer adapter on it. It worked fine then the battery died and now I’ve got this issue.
1 - 4 of 4 Posts
