1 - 4 of 4 Posts
S
Hi Guys can you give me some advice please?
I have a 1995 Camry with 178k on the clock. Every few days whilst
driving, the red warning light shaped like a battery and the yellow
light which appears to be the brake light warning come on
simultaneously for around 5 seconds and then they go out again, no
other symptoms are evident. Could this be the forerunner to a problem?
Also I find the remote key door lock/unlock is getting very sluggish,
sometimes I have to push the activator button on the key 5 or 6 times
before getting a result I have changed the battery in the key but that
has not helped. Any advice would be really appreciated.
Alex
D
Guest
Discussion Starter #2
For the warning lights, replace the alternator brushes - by the time
you get to 178k, they've simply worn down to the point they're only
making intermittent contact. Not even necessary to remove the
alternator from the car, just carefully remove the back cover:
> All this talk about brushes and brush holder. Where do you get
> them? My toyota parts just gives me a blank stare. Is there a part
> number? Sorry to be late on this question. Ed
Ed, ask for part number "27370-35060", this is brushes and holder,
easiest way to go, retail is about $16
For the remote activator button, you may just have to replace the unit,
but first try removing the cover and spraying the contacts under the
button with WD-40. Try to minimize overspray and then wipe dry
surrounding area - worked for me.
W
Guest
Or try the other remote activator.
"Daniel" <[email protected]> wrote in message
news:[email protected]
1 - 4 of 4 Posts
