1 - 6 of 6 Posts
The stereo cables don’t match the wiring guides. It is the OEM radio. I tested the new radio to the car battery so I know it works and powers on, but no cables inside of the car match any diagrams online.
282795
Have no clue, I haven't cut off a wiring harness in 20 years. I've always used an adapter. For $15, it's so worth not having to figure out what goes where, and no chance of making a bad splice 10 years down the road.
That does not look stock. Factory harness will almost never have wires of same color on same connector. I'm guessing there's gonna be a splice somewhere up the line to the actual factory harness.
If all else fails, find the pairs of wires that are going to have ~4 ohm resistance - those are your speakers. You can use AA battery to the identified speaker wires to find which is which. 12v, ignition, and ground should be easy enough to find. The remaining 2 wires will be for power antenna.
Good luck!
I have seen a harness like that before. Not in a Camry but still. You see the silver dots? On the car I was working on, one dot meant positive, two dots close to each other meant negative. This was on a 1986 Celica ST.
The green, red, 2 of the black, 2 of the white, and the brown would be your speakers. Blue would be the antenna wire. Yellow would be 12v constant. 1 white would be switched 12v. Black should be ground. Thats what it looks like to me. Which one is which exactly, I couldn't tell you. With a multimeter I could.
2000 Camry XLE
Wow, I am saving this post for later, just in case. I have no idea how you knew that!
1 - 6 of 6 Posts
