its currently keeping me off the road 🤣Problem is, that the rust is whats keeping a lot of cars on the road!
that black under-coating can be sketchy!Fiberglass and black under-coating, you'll eventually forget all about it, honest!
If it helps, your Celica ST, if it has the 7A-FE engine, is body code AT200. The same part number you stated is also on the Celica ST204 (which is the Celica with the 5S-FE in it). That would greatly increase your chances of finding a good one. I know the pick-n'-pull near me has several AT200's and ST204's in the lot. I don't think they would remove this subframe and ship it to you though. But as mentioned, www.car-part.com list salvage yards near you that you can see if they have such a car - and they may remove this subframe and sell it to you. Not all that easy to remove this particular suspension cross-member though.I just bought a 1995 Toyota Celica the crossmember was rusted out I'm looking for a crossmember sub frame part #51201-20300 if anyone knows the best way to get parts OEM or aftermarket I'm new to cars i just need these parts asap
So was my Corolla! It was fully removed by my nephew using hand wrenches, no power tools used, but it came off relatively easily for him and i, even with all the crusted bolt threadsBunch of stuff on it and attached to it!
If your question is related to my response ...... my response was more of "it will be a challenge for some who has to go out to a salvage yard and remove it". You can't always bring all the tools you will need out there. Not many ways to lift the car to safely get underneath it in a salvage yard either. And it is winter in Wisconsin here. That was my perspective.How does it compare to same year Corolla that makes it more of challenge to remove?
My local salvage yard that has these is a pick-n'-pull yard only. They wouldn't do what you stated - they remove engines, but that is about it. So my frame of reference was someone who had to do all the work themselves.Salvage yard would lift it with a fork lift and cut that out with a torch. Once it hit the ground a couple more cuts to remove the debri.
