1 - 14 of 14 Posts
Do i have these hooked up right so far? in the back where there are the two lines coming up at 90* from the intake manifold where do those go. i know what line hooks up to the bigger Emissios Valve set but cant figure out the rest help pleaseeeee and thaks again
Super Moderator
There should be a sticker on the underside of the hood showing the vacuum hose routing.
1996 vacuum lines
yes, i know, and i even have the engine service manual on my ipad and went step by step on there and its too hard to see. and i have the 1mzfe service manual but not avalon so idk if things are slighty dfferent but yea.
If anyone can take a picture of theirs of soemthing would be really appreciated. i did a complete rebuild and now im hung up on this stupid part
Can someone help a fellow toyota brotha out and snap a quick picture of those i cant figure it out and i have spend hours looking throug the 1mzfe service manual pdf and searching images online. and still no success
01 Avalon XL, 03 Avalon XL
Well, I'd try, but I have the dual intakes on the 01, and I have no idea what else might have changed from 96 - 01.
(You might have to be patient - 30 minutes here is like a nanosecond on forums with more traffic.)
You might try in a similar-year Camry forum, specifying that you need it for the V6 3.0 1mz-FE, since a whole bunch of long-lived Camrys had the I4 engine(s). Avalons are Camrys.
Super Moderator
It’s not clear to me if your ‘96 is missing its vacuum label, but if it would help, I could take and post a pic of mine. It’s a ‘96 with CA emissions, which might be different if yours has Fed emissions.
Discussion Starter #9
could you take a picture of the same spot i did please. that would help me the most mine is ca too should be the same hopefully. but where the two vacuum lines come out and up at a 90*
Super Moderator
I took a few pics of mine. Hope you can see what you need to see.
Part of your problem is your EGR Valve is connected to Intake Vacuum, The pics and Diagram from BMR should get you going in the right direction!
Discussion Starter #13
vacuum lines
i figued it out. what was messing me up was where the egr goes to the harness was broken off right at the harness so i couldnt tell anything ever went there. and it got me all messed up
1 - 14 of 14 Posts
