1 - 6 of 6 Posts
I have searched the threads and found an answer, but I still cannot figure out where this is.
The car is on jack stands, front passenger wheel removed, shroud removed, and I still cannot figure out where it is.
Does someone have a diagram or a picture of the exact location? I have read that it is under the water pump and that the electrical connection is on top of the water pump.
1996 Tercel.
TIA
The only thing I can see going anywhere near the crankshaft is a wire next to the oil dipstick that traces to the engine block above the starter. I can feel this wire and around it, but cannot feel a 10mm nut.
So, is this thing on the front side under the water pump or the back side near the starter/alternator? Is it directly connecting to the engine block?
The picture below is what I believe to be true, but if it is true, I cannot feel the 10mm nut.
TIA
1 - 6 of 6 Posts
