Last month I was troubleshooting a starting-relay issue, and a cigarette lighter socket that wasn't working. Worked on the starter relay, then the cig lighter. To get the front dash panel off, I had to shove a key into that keyhole to move the gear shift backwards to clear. Problem is/was, that when I buttoned everything up, and then tried to start the truck to test, the gear was thankfully in Neutral. Anyhow, both were fixed, but I immediately got the P1780 code, and it hasn't gone off (and it comes back soon after clearing the code).
Thoughts here on the likely culprit? What could I have fu-barred? I did search the forum here but couldn't find anything with a '97, as the 2000 model has the features discussed in the threads that I saw here.
Thanks gang!
-Alan
'97 4Runner V6, 352K miles
Thanks gang!
-Alan
