hello. bought a 97 used camry from a family friend. 140k miles. everything is mint. was told the front bushings were bad though. took it to a mechanic, he said my rear subframe is rusting and needs replaced. he quoted me 1.9k to fix. the subframe was 899$. when i look up subframe i see two types. one that is front and back, and then just a rear. neither are 900$. the most is like 250$. I called the mechanic and he said i needed a rear sub frame but couldn't get me a model number. i don't want to buy the wrong part. what do i need? what happens if i just drive this thing around as is.
here is the video he sent, if you go to suspension.
Hi ERIC, here is a link to your 1997 Toyota Camry CE inspection: {suspicious link removed}
