Have DIY timebelt for this model?
this car has automatic tensenor, but I am not familiar on V6 timebelt.
My question is... do I need set CAM1 and CAM2 (camshaft 2) both with off half a teeth and also crank spocklet? worry when i release the automatic tensenor, the belt will jump and cause the belt to be mark off.
when I try to install the automatic tensenor, it feel tight when tight both screws... worry, i might strip the bolt, or is that normal?
do i install the automatic tensenor before the timebelt or after the timebelt?
does someone has DIY how to deal timebelt with automatic tensenor?
try to help a friend out...
on 6 cylinder, i need to rotate clockwise 720 degree to light up the marks...
does cam1 and cam2 need to rotate clockwise 720 to line up the mark?
