Hello everyone,
Im new to the Toyota Tacoma family and im looking for a repair manual.
I cant seem to get power to my fuel pump.
Does any one have a repair manual they could send me?
Thanks in advance. :nerd:
Yer best value is to download yer factory service manual and electronic wiring diagram from Toyota's Techinfo website. Fer $20, you git 48 hours to download all the manuals you need. http://techinfo.toyota.com
I'm not auto mechanically inclined so apologies if I describe things inaccurately. I have a 1999 Pre-Runner V4 that my local mechanic went through all kinds of manipulations to solve some check engine light issues after replacing the drive shaft. He replaced all wiring, ignition coils, plugs...
I ask that as now in the market for a winter car with AWD or 4WD capability. Subaru was first on my list, but, given their head gasket issues, I am not anxious to take one on, in my price range.
Then it struck me that Toyota makes some, that I have ignored due to early on issues. But now...
I recently replaced the left front wheel bearing on my 95 Tacoma. It drives smoothly now and is quiet.
However whenever I brake now, I can hear (and feel in the brake pedal) the ABS system activating as I slow to about 5 mph. Otherwise everything seems fine. The ABS light is not on.
When I...
I need a driver side head.
What are your thoughts on After market heads any good brands? Remanufactured heads? Purchasing OEM? Amazon, Ebay, Autozone, Rockauto? Should I do both heads while I am here? Or just adjust valves on the other side, lap them, or leave it alone (not broke don’t fix)...
I frequently have wet passenger floor carpet lately on a 1999 Tacoma SR5 2.4L 4-cyl. It started a couple summers ago, and got advice here to ream out the A/C rubber drain tube under the engine and passenger compartment. That worked fine as it was blocked and lots of water then drained out. Did...
