1 - 2 of 2 Posts
Can the fuel connector pictured be changed easily? I changed my fuel pump and now I'm having trouble starting my Camry probably because of lack of fuel pressure. It's leaking really bad at this connector. It's the type with the two tabs on each side. The videos I've watched do not show any special tools needed to make this connection. However, it will not lock into place now. Are there any orings that need to be replaced? This connector looks as though it just pushes onto the line coming from the front of the car. I would appreciate any help. Thanks in advance!
Paul
292309
Hello Paul,
Your dealing with a thermo formed nylon line there, not the easiest thing to replaced. The elbow connected to looks like it isn't fully seated onto the sending unit. And may i ask, what kind of screws are holding the mounting bracket on?:unsure: They don't look like the OE bolts
1 - 2 of 2 Posts
