1 - 2 of 2 Posts
I am looking into putting a towing hitch on my 4 cyl. camry LE. I've read that max towing weight is 1000 lbs in some places and others say 2000 lbs. Does anyone know which is correct?
I am looking to pull this trailer http://kansascity.craigslist.org/for/1135984097.html
With a 940 lb mower on top.
does this seem feasible? Do i need to worry more about my transmission or braking?
Thanks for your help!
Ninja wrench anywhere
According to the '99 manual (which should apply to your rig, too), total weight of trailer + cargo can be 2000 lbs, as long as the total gross weight of the car + stuff in car (including the passengers) + trailer + cargo doesn't exceed the GVWR on the car's door sticker.
Hope you're not planning on doing this long-term -- the car itself only weighs about 3100 lbs -- towing nearly a ton on a regular basis is not going to be good for the brakes, tranny, or your sanity.
See http://www.camrystuff.com/manuals/Gen4/Miscellaneous/99_Camry_Owner_Manual.pdf page 173.
1 - 2 of 2 Posts
