1 - 2 of 2 Posts
Most Toyota engines are non-interference engines. That means there will be no damage if the timing belt breaks. The car will simply stop running and you will need to tow it to a shop (or home) that can replace the timing belt. To be sure is your engine falls in that category, go to the following website and check your specific engine:
http://www.gates.com/downloads/download_common.cfm?file=TBR05.pdf&folder=brochure
Mike
1 - 2 of 2 Posts
