also interested in this..
let's get some others interested!also interested in this..
Good job getting the engine wire out intact!So..couldn't help but jump into this one:lol: I began about a week ago with this swap. I've done this kind of thing before(should of learned) but i guess i just like the challenge. I have a good friend with a scrap yard so i have an advantage over some i understand. The swap car is a 2002 with 3spd auto and the donor car was 2001 manual. because i had the luxury and wasn't sure exactly what i would need i took everything. Dropped the K frame with engine/trans struts etc. i also took clutch master cylinder and pedal as well as shifter and cables. This is where i went a little further than necessary i took the entire wiring harness complete without cutting anything as well as the ecm. Its not that complicated esp the 3spd to 5spd conversion. I won't need the harness or the ecm. But if anyone who would like to do the swap from 4spd auto to 5spd manual would like the harness/ecm pm me i can definitely hook ya up.![]()
that sounds great! mind showing some pics? or maybe a walk around video? I'm really interested in this project with my mechanic uncle. How much did it cost you for gathering all you needed?So..couldn't help but jump into this one:lol: I began about a week ago with this swap. I've done this kind of thing before(should of learned) but i guess i just like the challenge. I have a good friend with a scrap yard so i have an advantage over some i understand. The swap car is a 2002 with 3spd auto and the donor car was 2001 manual. because i had the luxury and wasn't sure exactly what i would need i took everything. Dropped the K frame with engine/trans struts etc. i also took clutch master cylinder and pedal as well as shifter and cables. This is where i went a little further than necessary i took the entire wiring harness complete without cutting anything as well as the ecm. Its not that complicated esp the 3spd to 5spd conversion. I won't need the harness or the ecm. But if anyone who would like to do the swap from 4spd auto to 5spd manual would like the harness/ecm pm me i can definitely hook ya up.![]()
Hilet's get some others interested!
Hi brother did you ever do the Toyota Corolla 3 speed transmission swap?Lately I've been very interested in attempting this swap. Most of my travel is done on the highway and my high revving corolla in third gear isn't saving me the gas.
I've been reading around and found that my 3 speed is easier to swap out than a 4 speed. Can anyone inform me on what exact parts will be needed? Also, how much would it cost to have it done at a shop, and how much if I take on the project myself?
Thanks Forum! :thanks:
Hi bro email me ....... did you ever do the 2002 3 speed transmission swap? I have a 3-speed Toyota Corolla transmission as well I want to swap it outmLately I've been very interested in attempting this swap. Most of my travel is done on the highway and my high revving corolla in third gear isn't saving me the gas.
