1 - 2 of 2 Posts
I have just purchased a 1998 Tercel with 200,000 kms and have noticed a noise coming from the passenger side of the engine. The noise sounds pretty much identical to the noise in the video
. I don't think I have an oil pressure problem like the guy does in the video. But the car seems to run fine other than the noise. Any ideas what it could be?
N/A bites
Paseo
Seriously there are many things that can make similar noises. Do you have any mechanical skill? I ask because I'd like you to remove the upper timing belt cover and look inside to see if anything is wrong looking and if the noise gets louder. But first take the alternator and air conditioner belts off. See if the noise changes. Only run it like this 10 minutes because the water pump won't be cooling.
1 - 2 of 2 Posts
