1 - 4 of 4 Posts
1998 toyota tercel
Hello,
I'm a bit confused in regards to the 2 tire sizes given, like in the tire pressure section you can see it says 185/60r14,
But then down below it says on 2 occasion 185/65r14,
So I wanted to know if this was a mistake or if the small difference in the aspect ratio doesn't really matter?
Thanks!!
1995 T100 2WD & 1993 MR2
Since the car doesn't have awd,4wd or a posi in the differential the small difference between the 2 tire sizes shouldn't make a difference. Not recommended to mix tires but do what works for you!
1998 toyota tercel
So is it okay to set the psi of the 185/65r14 to sane suggested psi of the 185/60r14?
1 - 4 of 4 Posts
